Spreading components away from each other uniformly
Is it possible, whether a feature or a hack, to scale a group of components without changing the size/dimensions of the components that make up the group.
or to pose the question differently… how can i scale the space between a group of components without changing the size of the model itself.
or =)
you know that demonstration of the expansion of the universe where someone draws dots on a balloon. then when you blow up the balloon the dots move away from each other uniformly…
can i do any of those in sketchup?
You can make them a dynamic component. So that each component is a fixed size and can’t be scaled.
If your components are all the same, you can also copy/array them.
I think i see where you’re going with the dynamic components suggestion… thank you very much! i am not sure i follow the copy/array suggestion thing though.
I am going to go attempt the dynamic component piece, if you can spare the time to elaborate on the other suggestion i’m eager to learn
another way…
http://sketchucation.com/forums/viewtopic.php?f=323&t=24390
@quantj thank you very much for the dynamic component suggestion!!! it worked like a charm!!! it took me a second to remember how to lock the attribute on the components but as soon as i did everything worked exactly as i had envisioned.
if i had just found this forum last night before i “brute forced” the other half of the issue i created for myself =) i’ll definitely come straight here next time i am trying something new.
@Cotty I cant wait to see what kind of ingenuity you have shared, but my proxy is blocking the link… i will check it when i get home from work.
Great to see you figured it out!
You could also have used the BigBang extension.
-Gully
