The problem is that in this way it limits only the internal component, leaving the external with a different measurement, without warning in the component options, would anyone have a solution for this?
The example uses current, smallest(largest, value) as a range and ceiling which allows significance like 0,5 (half meter)
You need to choose the method of input, scale or option text box, so input is not overridden
Block with hole example.skp (82.0 KB)
Examples from left to right, scale only, text box input only and then option to choose,
“Current”, when directly used in the size attributes returns inches not centimetres, a bug which one has too work around with a conversion.
“FaceArea” is a function that is noted to return square inches, so convert with 2.54*2.54.
