Snapping in Layout
In SU Layout 2016 I used to be able to leave position lines on a layout sheet and use object snap to help me to snap the imported drawing to the line.
This doesn’t seem to happen Lasyout 2020
It should. Can you share a LayOut file with the set up you use?
Hi Dave,
The working file is too large I’m afraid.
I made up this test sheet
TEST SHEET.layout (718.1 KB)
What are you trying to snap the model viewport to? I don’t see anything but the viewport. And are you using the precision placement doodad to do the snapping?
I drew in a rectangle and then snapped a point in the viewport to a corner of the rectangle. Works as expected.
Hi Dave,
I would normally draw a line and place it where I would want the corner of a window or elevation (say) would be placed on a drawing sheet.
And then move the insertion point for the viewport to the corner of the window before moving the viewport? Like I showed in the GIF?
Thanks Dave
I see that I neglected to place the snap point (my term.)
That’s an important part of it.
