In sketchup2022, right-click on the line and press the D key to split the line segment, which is very convenient. But 2023 did not work and became an invalid command. Almost all right-click functions have this issue, which greatly affects usage efficiency. Eager to fix this problem earlier
That is a shortcut you had set in 2022. If you select a line, then go into Preferences/Shortcuts, and search for Divide, you can add D as the shortcut to use.
感谢您的解答!请允许我使用中文表达。不只是拆分线这一个快捷按键,还有其它好多功能是同样的问题,如果都要设置快捷按键,但键盘的按键几乎已经被设定满了,没有多余可用的快捷按键。如果不能像sketchup2022那样,那么我用sketchup2023工作,要比2022慢许多
