hi there,
I tried change shortcut for Line, main shortcut is L, but when I try to change, SU is freeze and than I force quit it.
it’s not so big problem but will be better for me tools shortcut get from left hand.
SU 2022
mac os
with best regards
That’s a problem we know about. It will be fixed in the next SketchUp update.
Meanwhile, if you close SketchUp and then go to Finder, and choose Go to Folder… from the Go menu, paste in this text:
~/Library/Application Support/SketchUp 2022/SketchUp/SharedPreferences.json
that will take you into the support folder, and will highlight a file named SharePreferences.json. Open that file with TextEdit, and look for this line:
"Shortcut_3": "0 0 0 L selectLineTool:",
Edit the line to change the L to the key that you want to use for the shortcut. Make sure to pick a letter that isn’t used by another shortcut. Save the file and close TextEdit. Reopen SketchUp, and the new shortcut should work.
thanks
