Hello all, I need help with the following issue:
Sketchup web crashed and now my model is broken.
I have copied the broken part to a new file to share it and removed everything else.
Basically what is happening, a component which contains many other components is not visible (even though the tag for it is enabled). This component is part of another component and when I open this it suddenly becomes visible.
I can however not navigate into the ‘broken’ component and I can only select it by dragging the mouse and select everything.
Also, which I just found out if I zoom out it becomes visible too.
Hidden Geometry and hidden objects is turned off. EDIT: but changing it has no effect.
Please check the screenshots: Imgur: The magic of the Internet
I noticed that the Materials seems to be broken in the entity info but even if I change it is has no effect.
I am checking how to share the file and will add it too
Edit: link to the model: SketchUp
