SketchUp Viewer Beta with Passthrough is live!
Hi everyone!
The SketchUp XR team is happy to announce that SketchUp Viewer Beta for Quest is now available on Meta’s App Lab, and offers exclusive access to early prototypes for upcoming features. If you have Quest 2, Quest 3, or Quest Pro, you can now join the Beta by following the instructions below to test the brand new Passthrough feature!
Step 1
Click this link to open SketchUp Viewer Beta on App Lab, sign-in using your Meta account, agree to Terms and click “Join”
Join
Step 2
Put on your Quest device, go to the Store app and search for “SketchUp Viewer Beta”. The app will appear under App Lab at the bottom.
AppLibrary
Step 3
Click “Download” in the app’s Details and then “Start”. You can later open it through your Library, and pin it for quick access.
Download
What do you think of the Passthrough feature?
Leave your feedback in this thread, or record a video directly on your Quest device and submit it using Quest’s Playtesting Feedback!
We can’t wait to see and hear how you will use Passthrough in your workflow!
Best,
Aris and the SketchUp XR team
Getting an error that the Beta app has expired and to download the latest build?
There is a full Sketchup Viewer app now. You can find it in the meta store if you’re running a quest headset.
Hi @mgerberman
Apologies for this. There are other users reporting the same issue. Our team will investigate.
Thank you for your patience,
Aris
Hi @mgerberman
It seems that there is a mix-up with the available releases of the application. We have now removed all older releases and a fresh install should fix the issue.
If that does not work, there are two ways to force-select the right channel:
Way 1: Go to the Meta stores page in the desktop browser and locate the SketchUp viewer Beta app. Under Additional Details -> Version + Release notes change the channel from Alpha to Live!!
Way 2: In your Meta Horizon mobile app, locate the SketchUp Viewer Beta app in the store. Under More Information click the version that’s listed. Change the channel from Alpha to Live
I hope the above helps,
AK
