SketchUp Skill Builder video: How to install an Extension
#1
Check out the SketchUp Skill Builder video: How to install an Extension by our very own SketchUpper and Team Member @AlexB Also, make sure to check out our Help Article to learn more.
Skill level: Beginner
Skill developed: Installing an Extension
Please try this Skill Builder and post here and exchange ideas, alternative methods for any given exercise or ask questions.
To check out more Skill Builders, head on over to our YouTube channel.
How to install an Extension: Tutorial
Rounded Corner Plugin?
Best plugin to make printable origami with on SketchUpMake?
Plugins and Ruby consol?
Setting up a complex walk through for a 3rd party to view; possible?
How do i create plugin in sketch make?
#2
It’s worth adding here that on the rare occasion that you only have a .rb file you can still install it using the built in Install Extension button, without needing to know where the plugin folder is.
Simply make the .rb into a .zip file, using winzip or similar, then change the file extension from .zip to .rbz
Once you have a .rbz use Install Extension button to install it as described in the video.
#3
I also think that it is worth mentioning that the SketchUcation community has developed many other great Extensions, that they call “Plugins”, and you can learn more and explore what they offer by checking out their site here.
#4
I actually had a harder time installing them then learning how to use them, and looked only for the auto-install versions. It is something you need to figure out as/if you move toward creating texture libraries, importing free texture samples, rendering tools and such. More of building your computer knowledge or skills that will improve your confidence, especially if you have looked at or want to attempt dynamic components.
