SketchUp pro render software for MacBook Pro
Hi,
I moved to a MacPro M1 Max (32Gb) from a desktop Hackintosh, I do a fair bit of visualisation and have used VRay and Twinmotion for a number of years.
Twinmotion (although still running under Rosetta) seems to work very well for me, and apart from a small annoyance over the pointer click targets in relation to some UI elements (there seems to be a 10 pixel discrepancy), Output speeds are vastly quicker than my previous machine (i7 8700k, 64Gb RAM, Nvidia GTX1080Ti). Saving and opening large projects are significantly quicker on M1 due to the fast SSD.
Twinmotion is pretty much all GPU as its realtime and shares the same very fast memory pool as the CPU.
Epic / Twinmotion team say they are working on an M1 native version for release later in the year.
VRay is M1 native but does not utilise the GPU for rendering. Chaos only support GPU rendering via CUDA and RTX on Nvidia hardware (which is why I originally built a Hackinosh). So rendering is CPU bound. This is unlikely to change (ever) unless Apple implement ray tracing hardware to their GPU cores and a robust Metal raytracing API.
Maxon Redshift is M1 native and utilises GPU rendering on M1 but no Sketchup integration.
Octane X is optimised for GPU rendering on M1 Pro/Max hardware and there is a Sketchup integration.
I’ve never used it so couldn’t comment on its integration interface or how up to date it is.
On your hardware choice, I would say that 16Gb of unified memory is not sufficient IF you were to use something like Twinmotion. TM likes lots of memory, Ram and vRAM (although in the M1 case its all a single pool). Renderers are faster if they can keep high-res texture and geometry etc in memory. Even with out-of-core capabilities, pageing stuff in and out of disk (even the very fast SSD on MBP’s) is nowhere near unified memory bandwidth.
Personally, I’m re-tasking the Hackintosh as a PC render node for more complex projects (as I’d like to transition to UE5 eventually) and using the MBP as my primary design tool and for general Twinmotion stuff (sans path tracing). If you are happy with CPU renders, VRay is very good and the SU integration is great.
