Hi, so when I save my sketchup files it is only saving them to skb files, and there is no skp files which is the normal file type. Does anyone know how to fix this?
I figured it out, for some werid reason, when you go to ( Save AS ) - it put .skb at the end when the only text should be the file name
This sounds like something screwed up with your installation of with what you have File Explorer set up to display.
To me this sounds like you pc is set to hide known file extensions in explorer, so you don’t normally see the .skp on a SketchUp file, but .skb is not a known type (because SketchUp doesn’t register to open them) so the .skb is visible. To open a skb you must rename it to .skp.
