Sketchup on Ipad & Onedrive: I see files, but cannot open them
Going to Onedrive on my ipad, selecting the skp-file to be opened via “…”, the file opens.
If I open Sketchup Pro on the Ipad and try “Open from”, I can go to the same files in Onedrive, but the files can not be opened… what goes wrong?
Download the file to a local drive, then open it. When finished upload the file after saving. It is best practice to work on files that are on a local drive. When working on a file opened on a nonlocal drive is like playing Russian Roulette.
Thank you for your answer! But it is strange that I can see them, but cannot open them? A bug?
On iPad or iPhone, you need to be opening through the files app and then they should appear in the recent models from within the SketchUp app.
@superline thanks for posting your report here, much appreciated. Apologies for the trouble you’re having working with models that are stored in One Drive.
Opening files from the OneDrive app in the way that you’ve described via “Open From…” should be possible. And it is odd that if you start in the files app, and then open the file in the SketchUp app, that works, but the Open From path doesn’t. Probably something here for us to look into.
Can you please confirm for me which version of the SketchUp app you’re using, and also the approx file size of the model you’re trying to open?
Good Morning, thank you for your reply!
App used: Ver 6.2.0 (1937). ipad OS 16.3.1
Approx filesize: 300 kb
I can see .dwg files… but the skp files are all vague.
work to do?
Hello, I am having the same issue. I use Google Drive, and since I updated the Sketchup app on my iPad I now can’t open files from G drive, they are greyed out. If I open the file from files as suggested above, they will open, but not from within the app itself.
Hi, I’m having similar issues. I’m brand new to SketchUp. I’m using the free web version. I’m trying to follow along with a LinkedIn Learning course on SketchUp. I downloaded the learning files (SKP) to my iPad but when i go to he “open from device” option and get brought to my files all the skp files are transparent and I can’t open them.
Am I doing something wrong?
Thanks for your help.
There may be some confusion here. SketchUp for iPad is an app that you download from the Apple App Store. It is part of the SketchUp Go subscription. SketchUp Free is a web app that runs in your browser.
Hi Steve. I’m aware of this. I am trying to use the web app in the browser. I just downloaded the iPad app to see if that would solve the problem
I’m having not being able to open the files.
Love it too much
Hi all,
Circling back to ask whether any of you have any other 3D modeling apps installed on your iPad? We’ve traced issues similar to those being reported here, so some misbehavior on behalf of apps like uMake and the way that they attempt to claim ownership over (and thereby disrupt) the proper handling of SketchUp files and other formats.
If you have apps like this installed, I would recommend that you try uninstalling those apps to see if you notice a difference.
Hello, uMake was the issue and after having deleted it, I was able to open skp files from iCloud THANKS
I can’t open SketchUp files on my iPad when the file is located on my OneDrive. I use the open from and choose the file from OneDrive and nothing happens. What’s up?
Hi there. I have the same problem. I can see the content of the file but cannot view the files, cannot go through the modelled spaces. I uploaded the files on my iPad and tried accessing the files from local drive but didn’t solve the issue. Whenever I try to go into the sketches, program crashes and returns to desktop home screen.
