Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions
Yes
Hyper-V - Second Level Address Translation Extensions
Error code 115 means that there is a connection point that was made improperly somehow, possibly during a copy/paste operation or duplication of pages that contained connection points. Connection points are what LayOut uses to connect labels to SketchUp model viewports, for example.
This was likely not something you did wrong, but rather a bug in LayOut that produced this bad connection point.
It may be possible to recover this file by manually editing out the bad connection point (the usual method is to rename .layout to .zip, extract the zipped contents, modify the appropriate .xml file(s), then rezip the contents and rename back to .layout).
We are looking at a way to automatically fix this 115 error in the future such that this error should never be seen again.
Ok, I just renamed it to .zip and extracted the zipped contents as you advised.
I do not know which .xml files are not appropriate and how to fix them.
Could you advise me about this?
I have extracted .xml files such as
document.xml
documentProperties.xml
references.xml
styleManager.xml
I have attached all of .xml files below in the zipfolder.
Sorry I misunderstood about the .xml files.
There are a lots of .xml files in extracted the zipped contents.
Anyway I have no idea about the bad connection points and how to recover this file by manually editing out.
I am trying to copy the all text and hatching data from original layout file to new layout file, and linking it to new SketchUp files copied from original SketchUp file. As I assumed the bad connection is happening between the original layout file and original sketchup file.
