Hello, I’ve been having problems with importing dwg file into the Sketchup. I’m trying to make terrain model, so I imported contour lines from Autocad but as a result I got few very close lines. I tried importing with older versions of CAD, placing it close to Origin and leaving only 2 layers. The file has 206 KB so I don’t think it’s too big.
Does someone know what may be the problem?
When imported, it did have 4475 edges, but they were extremely stretched out in the z direction. I flattened them with Eneroth’s Flatten to Plane. If the contours were meant to have height information, then obviously that’s been lost here. I don’t know what scale it’s meant to be, but you can resize it yourself.
The import does work if you use km as the unit, with a warning that some geometry is too far from the origin. Even when you think the import is ‘bad’ , switch to parallel projection, Camera->Standard Views->Top, Zoom Extents and you’ll see the contour map.
As you said, I lost the height information so I tried it with old file. I managed to import it yaayy me (thanks to you:D) but another problem appeared. Only few contours have their height. Does this mean there is a problem with my dwg file? I don’t know where it could’ve gone wrong.
Yes, I see. I was trying to adapt it to my area but it’s obviously more complex than I thought it would be.
This file is not that big mess, but still I get the same result in Sketchup. relief01.dwg (395.5 KB) Real terrain height is appearing only on few places, as you can se from here:
Hello sir… I’m facing the same problem and I tried using the Eneroth’s Flatten to plane extension as well and it didn’t work for some reason. Can you please help me with it too? I don’t know if it’s too much to ask, but I really can’t go forward without it and I don’t have anyone irl to help me with it. Thank you.
The scale is astronomical. Even when using Millimeters as the import unit, there are edges a couple of hundred kilometers long. They might be boundary lines that stretch some 173 kilometers in the blue direction. What is the unit used?
You can flatten the contour lines, and then, if you know the level difference between them, you can reposition them on the Z axis with Elevate Contours plugin.
