sketchup crashes during using offset tool repeatedly
im using 2024 sketchup and always when i’m using a same offset for same geometries a little bit fast it crashes
it does not related on my file because i tested empty space and it did crashed again
it crashes on all types of geometries(triangle,circle,…)
im using i5-1320 and rtx 4050 laptop
maybe it’s a bug that was fixed in a later version of SketchUp.
Does it do it if you run the latest version?
Is it a cr acked version of SketchUp?
Upgrade to 2026. You can even keep your old version installed to make sure everything works well in 2026. The files are all interchangeable.
Unless you are not running a legal copy. Then
¯\_(ツ)_/¯
I can confirm this problem as well. It’s been a consistent bug since at least sketchup 2024. Currently on 2026 Pro, not cracked. Windows 11, always current version. Nvidia GeForce RTX 4090 card. Repeated use of this tool will cause a crash 100 times out of 100. I have sent out mutiple crash reports on this over the years and it is yet to be fixed.
Hi @EliteBrian, thanks for the post. Can you list a few bugsplat report numbers? Maybe one of our other team members can look at the reports and see if they can find a common factor between the reports?
I would test it myself and see if I could log things for you but I am on a Mac at the moment and will not be back home until later this evening. Once I am home though I will be able to run some test on a Windows computer though so even if you do not have bugsplat numbers I may be able to reproduce the error if you can let me know any details I need to know to cause it.
Hopefully we can find out what is going on and find a way to help you out.
