Sketchup 2025 / V-ray 7.00.2 - Globeplants textures load with squares
Hi,
When I load a model a new sketchup file, the render output of the object is not ‘cut-out’ but instead, a strange colored square is placed along the initial outlines.
Here, you can see the “green / amber” leaves to have squares around them…
Any advise?
Have you contacted Customer Support at Chaos Group about this?
Not yet, was looking for info on this one but no luck yet.
Since this release is so new, it might be better to go to the source. Maybe you’re the first to run into this issue.
There were issues with the Laubworks plants not following the new V-Ray Material setup that are part of V-Ray 7.
Perhaps this is the same thing.
It looks like the alpha channel for the leaves isn’t being used correctly.
V-Ray 7 is doing something similar to Laubwerk’s plants as well. Note that the diffuse, alpha, etc paths are all mapped correctly but not displaying in the render. I’ll ping chaos as well as I’m afraid with Laubwerk getting acquired by Maxon, we may not get a solution, or it may not be within Laubwerk’s power to solve.
Edit @Elmtec-Adam - beat me to it. Unfortunately, if I want to use my very expensive plant library, I’m stuck downgrading to v6 for now :frowning:
Update Update: This Chaos forum thread states that it actually sounds like it’s Laubwerk’s problem to solve. Unfortunately not helpful for Globe Plants as I don’t believe they load via extension like Laubwerk.
Yes, I’m familiar with the issue w/r Laubwerk (I also experienced this, unfortunately).
However - Globeplants was working fine and the issue w/r the leafs showing as squares is not related to the issue described above. As can be seen here:
It seems like no material at all is listed, you can’t even change to V-ray material neither is there any way to load the materials correctly. Please note that the materials are correctly mapped in the asset manager (showing green…), but I do notice only the geometry is listed… that might be of interest…
2025-02-27 19_57_28-V-Ray File Path Editor
The same Lauwerk Plants models work well in Rhino 8 and Vray 7. Within SU 2024/2025 with Vray 7.001/7.002 they do not.
Just FYI, regarding Laubwerk: the recent V-Ray 7 Hotfix 3 update fixed this issue with the BRDFDiffuse layer. You should be able to use Laubwerk plants now with V-Ray 7.
Hello, I am trying to upgrade to Sketchup 2025 but the Laubwerks plant kit installer 1.0.51 only gives me an option to install for sketchup 2024. Does anyone know how to get the plugin file for 2025 so I can install it?
