Sketchup 2021 crashes on Export 3D and Export 2D
Reinstalled the program several times - same crushes
Is it with every model or just one in particular…the more information you provide the better.
every model even test model with one flat shape
on MacBook Pro 2017
2.8 GHz Intem Core i7 16 GB 2133 MHz LPDDR3
graphic card Radeon Pro 555 2048 MB Intel HD Graphics 630 1536 MB
Maybe its the system configuration that doesn’t allow to work with Sketchup 2021?
Works with 2017
It should work.
I found your crash report, thanks for sending it in. I can see that other people have had the same crash. I have asked a colleague if there is a known issue that causes that kind of crash.
Is there a reason you are using SketchUp 2021 and not 2022?
