Sketch OSM
Hi!
Does anyone own an installer file for the SketchOSM plugin? It was free, but it’s no longer available for download. If you have, please share.
Here’s an overview:
I just downloaded it from here: skp2osm - OpenStreetMap Wiki It hasn’t been updated for many years and may not work in the later versions of SketchUp.
Maybe take a look at this as an alternative.
The one from mind sight studios is just what I want, but it’s no longer downloadable. Skp2osm is a different plugin.
Oops! I missed that SketchOSM is no longer available. I see according the site it’s because it’s not compatible with the later SketchUp versions. I guess you might be out of luck for getting it since Mindsight Studios would be the legitimate distributor for it.
Yaaas, I just asked them to share the installer. Hope they don’t mind.
Hi, so why you don’t make it open source
Dave is not the author of the extension, and you can’t use extensions with the web based version… so I’m not sure what good it would do you (correct your forum profile if it is incorrect).
You can also try to see if “Oob terrain” is still working on newer Sketchup versions.
The plugin used to do a similar job with good results and many additional features for a fair $9 perpetual license.
I’ve only used it on Sketchup 2019/20/21, but it was updated after that.
I’m not sure if it’s compatible with later versions of SketchUp, but you could try contacting the author, who, in my experience, has been quite responsive in the past.
i asked if we can get it in open source and some one can make changes, that s all
Contact the author of OSM. It would be up to them. I don’t know why it would matter to you, though. Since you are a hobbyist using the free web version the extension won’t do you any good even if it is open source.
i want to use it with free version sketchup make (an old version) i use it for openstreetmap and use th featur roofing
You literally brought a 5 year old thread back from the dead by asking @DaveR if he could make it open source.
Contact the author of the plugin…
So you’re using SketchUp Make commercially.
Again, you need to contact the author of the extension and ask them to make it open source. No one else can do that including me.
If you call contributing to the improvement of OpenStreetMap is a commercial, sorry now i see you QI
… ok, take a breath.
you can’t help develop open street map on sketchup. you can only develop it on openstreetmap.
I don’t get it. what you say doesn’t make sense.
also,
Bro, I asked the author 5 years ago, they never replied. Just let it go.
If you like open source so much, maybe consider learning Blender. It’s way more capable of handling large spatial datasets than SketchUp. It also has plugins for OSM that are… you guessed it, open source.
