Skalp Update: Compatibility with SketchUp 2025
A new Skalp version compatible with SketchUp 2025 is now available for download from our website:
http://download.skalp4sketchup.com/downloads/latest/
Alert: Skalp Hiddenline Mode is currently not working correctly in SketchUp 2025.
Issue in SketchUp 2025
SketchUp 2025 has introduced a bug that prevents textures assigned to Tags from displaying correctly when using Hiddenline render mode in combination with Color by Tag. In Skalp, this setup is known as Skalp Hiddenline Mode.
Solution: Skalp Tag Color Manager
To work around this issue, Skalp introduces a new tool: Tag Color Manager, available in the Extensions menu.
Features of the Skalp Tag Color Manager
  1. Simulating Skalp Hiddenline Mode
• This tool changes all Tag colors to white, except for those with assigned textures.
• When using Texture Mode with Color by Tag, this setup replicates the original Skalp Hiddenline Mode behavior.
• The Skalp Hiddenline Mode button automatically applies the correct style settings.
  1. Restoring Original Tag Colors
• If you need to revert to your original Tag colors, simply use the Revert Tag Colors function.
Important Notes
• Due to SketchUp’s limitations, you cannot combine both styles within the same model.
• SketchUp has acknowledged this issue and announced that a fix will be included in an upcoming update.
We hope this solution helps until the official fix is released.
Thanks!
I’ve just shared an introduction to Skalp Studio 2027, with examples and more details about the new workflow:
