Size LenX -Y and Z value is not correct
I startet make a DC for steeltruss when i added attribute Lenx,Y and Z i showed bigger six´ze than the actual size.
The Tross components put to gether should be 150,30 and 30 cm.
What have done to make this happen?
options
strange size.skp (397.2 KB)
No one have an idea?
you have worked on the children without referencing the parent, explode the parent then select the two orphans, make them a component, new parent should match, however there is slight difference due to position differences between the two children
thanks! i exploded and made a new component, then it seems to be ok again.
