Size change problem, lenght automaticly
When you use normal 3D tool, archicad, autocad, thinkercad
. there already making a model (square, or lineal) it shows size. And they are so easy to find where to change the size of any object, that is made.
In sketchup, looking on the internet, there are thousands people over the world, having problems in every country, to find turorial for such a simple thing. Web is different from desktop version.
The videos shows mostly desktop versions.
From the beginning of sketcup you are copying pionees. This is maby the time, for people have normal options to change size, time to enjoy your software ,make it like other, do it better. Size change tool copy please it from dessasault system solidworks or similar or even better, thinkercad 3d. That is so primitive, but why in sketchup it is so an hard one option?? I’m not blonde, 38y, IT technician, construction manager. And having problems to find the option. That should be intuitive tool. The manual is not the best, and the tool is like a mono wheel bicycle
SketchUp works differently and it is very efficient. Try learning before you complain. It’s easy to make accurate drawings and adjust them.
You could benefit yourself by spending some time at The SketchUp Campus. This is a site that will provide the basics for learning the SketchUp modeling process. Also, spend some time at the SketchUp SketchUp YouTube site. It provides much information including how to use each tool.
