another step forward, or maybe backwards???
it very hard to guaranty an accurate end size for frame objects…
the earlier gif script, actually had a issue with not correctly placing some go the component instances…
john
I only remove the higgen edges and change axis on the walls, but doors and windows get reduced to single faces…
32 seconds with the ‘show’ turned on…
test3_reduced.skp.zip (1.6 MB)This looks promising. The only issue now is that the door/window frames is not part of the single faces, leaving a small opening against the walls. For the calculations I need the model to be fully closed ![]()
what I finding is I have far more control if I start with a .ifc file…
I can remove coplanar edges, create single components for identical items, sort them onto layers and make proxies for doors and windows and get them back in the right spot…
but with your file too much information has been removed to continue developing with it…
if you can private message me a .ifc I can see if it works with what I’m doing…
ifc_building_simplified.skp (3.0 MB)
it’s also about 76% smaller than the import…
john
