I created a pyramid with base 10’ by 10’ and altitude 50’. There are 100 pyramids with a 1’ spacing between them. I want to drag the vertex of each pyramid so that the vertex is located over the origin at the same 50’ altitude.
Is there any way to do this by editing the coordinates of all the pyramid vertices ? (so I dont have to click and drag EACH vertex)
Before copying, make it a component. Then, all copies (or instances of the definition) receive the same treatment when editing.(you need to open the component for editing)
I used mihai.s’s suggestion of fredoScale. The only thing is that box taper did not let me converge all the vertices in the chosen direction in one go. It went 90% of the way and any further then the outline would jump past the desired target location. I just repeated the process to get the vertices superimposed. Thank you all.
