mod = Sketchup.active_model
ent = mod.entities
sel = mod.selection
mass = []
arr = []
sel[0].make_unique
sel[0].entities.each { |entity| arr << entity.make_unique}
for i in 0..arr.length-1
t = arr[i].transformation
arr[i].entities.to_a.each{|line|
if line.class == Sketchup::Edge
if ((line.start.position.transform! t).z > 380.mm)
mass << line.start
end
end
if (line.end.position.transform! t).z > 380.mm
mass << line.end
end
end
pt = Geom::Transformation.new([0, 0, 100.mm])
arr[i].entities.transform_entities(pt,mass)
mass = []
end
Hi, If you change the local axis of the top middle section so the Z axis points UP instead of Right, then you might achieve moving the vertices Up instead of Right.
inst = sel[0].make_unique
ents = inst.definition.entities.map { |entity| entity.make_unique }
for child in ents
# code using child ...
This way you avoid any “off by one errors” and since your not really using the index for any calculations you might as well just use a reference to the child instance rather than repeatedly calling arr[i].
I tried and the result was the same. Is there any way to change the axes?
ent = mod.entities
sel = mod.selection
mass = []
for child in ents
t = child.transformation
if child.transformation.zaxis != (0,0,1)
#Is there any way to change the axes?
child.axes.set([0,0,0], xaxis, yaxis, Z_AXIS) #
end
child.entities.to_a.each{|line|
if (line.start.position.transform! t).z > 380.mm
mass << line.start
end
end
mass << line.end
end
end
child.entities.transform_entities(pt,mass)
mass = []
end
ent = mod.entities
sel = mod.selection
mass = []
for child in ents
if t.zaxis != [0,0,1]
pt = Geom::Transformation.new([-100.mm, 0, 0])
else
end
mass << line.start
end
end
mass << line.end
end
end
child.entities.transform_entities(pt, mass)
mass = []
end
Yes. You need apply certain transformation the group/component in a question to align its axes, then apply the inverse of that certain transformation to the entities of group/component.
