I am really puzzled by this one. I am trying to use the same Shadow settings in the Sketchup shadow palette as in this lovely tutorial by Chaos Group. https://docs.chaosgroup.com/display/VRAYSKETCHUP/Interior+Lighting+QuickStart
They provide a model file. When I apply their shadow palette settings I get darkness (4PM, 10/20). The green axis seems to be in the same place. I would be very grateful for some help here…
This is my file. I have removed all I could to keep it small. My model .zip (2.3 MB)
Also one more question: Is there a way to fix a scene to a model so if every time the model’s orientation is changed there is no need to create scenes from scratch?
Let’s say I rotate the whole model 45 deg and go into scene that is set to show the interior. But it shows some other view, often outside the model. And I was wondering if it’s possible to link the scenes to models?
I see. Are you thinking of rotating the model just to get the shadows to line up correctly? If so, you might consider a different approach. Instead of rotating the model, change the solar north angle. Install the plugin called Solar North from the Extension Warehouse and use it to set the angle of north. Then you can leave your model aligned as it is and the camera where it is for the scene.
