Not sure if this is a bug, or if it is just me!?
No sunday?
When i try to adjust the date for the shadows, 11 out of 10 times one column of the calender is out of reach/out of visible range? So i have to minimixe the window, adjust the date, and maximize the window again,. until the next date needs adjustments.
Is this a bug? If so, could you please make sure the calender is fully visible? Thanks in advance
DaveR
March 9, 2026, 2:22pm
2
I wonder if that’s a localization thing. This is what I see with Sunday on the left as is typical of calendars here.
Or could it be a screen resolution thing?
Hmm, no clue to be honest.
But i guess, if my week started on sunday, my saterday would be out of visible range
Unfortunately adjusting the shadows window did not help either
DaveR
March 9, 2026, 2:29pm
4
What is the display resolution set to?
It would be interesting to see calendars from other localizations to see who might be affected.
Both monitors are set to..
Scale: 100%
Resolution: 2560 x 1440 (recommended)
RTCool
March 9, 2026, 2:44pm
6
Strictly Windows. No such feature on a Mac - we have to type a date.
AnnoNiem:
2560 x 1440
What if you move the sketchup window to allow it to pop off outside of sketchup?
Is the screen with Sketchup on the left screen of the 2 by any chance?
Is your missing edge on the other screen? Under another window?
Anssi
March 9, 2026, 7:18pm
9
It is the same here too, the popup pops outside the sketchup screen border. Finnish regional settings
Here, the screen is not maximised:
Here it is:
Unfortunately, I use SketchUp on my main screen, on the right side of my desk.
Of course, I could also just type the date into the text field and skip the calendar altogether.
The localisation thing seems like a likely culprit , 2 character weekday abbreviations versus 3 must break the layout of that HtMl element
With the Spanish calendar they put a dot behind the two-characters abbreviation. It seems work.
I checked what happens with my setup, and it turns out I’d have the same problem. However, I keep my trays docked on the left, so the calendar spills over onto the drawing area.
Tthanks
I’m going to try this, hope i can get used to it
