I often find myself in the situation that I want to select encased objects in x ray view mode to copy/move them within an object.
For example wood pegs.
Unfortunately this often a somewhat cumbersome process since I can’t simply click on the enclosed objects to select them because sketchup will select the outer object.
As a consequence I usually have to hide the exterior object first to be able to click/select the interior object and then I have to unhide the exteriorobject again so that I have a reference where I can move my interior stuff to. If I click wrong everything is unselected and I have to go through the hole process again. So that’s very laborious and inconvenient.
Yes I could select my objects in the outliner but this would require that I carefully name everything to make this more usable and turning on the outliner makes my model often run slow.
Is there a way to “fast and easy” select enclosed objects in x ray view or a better way to do stuff?
