Select won't work the same in SketchUp Pro 2018
What has changed in Sketchup Pro 2018 so that the select tool doesn’t work. I can’t outline objects I want to copy quickly any longer. This is terrible!!!
Sounds like an error,
You are also using a fairly old card, what are the rest of the computer specs?
This is typically a graphics card issue. Newer versions of SketchUp require a graphics card that is up to the task. SU2016 and before gave you the option to turn rendering duties over to the CPU which compensated for a weak graphics card but with SU2017 and SU2018, that’s not an option.
