Sefaira - Analysis doesn't work
Hi, I have been trying to run an energy analysis with the Sefaira plugin in Revit 2024 but it doesn’t seem to work. Either nothing changes after I click on update analysis, or it completely goes blank. This model was exported in an IFC format and imported back into Revit 2024 from the 26 version. I tried running it with a simple model and it worked.
I have followed the modelling guidelines and assigned everything to the correct function type. I also replaced the windows with the Revit family file mentioned here - https://support.sefaira.com/hc/en-us/articles/115000733311-Suggested-Revit-Window-Family-to-Avoid-Plane-Count-Error
Hi
would you mind sending me the model directly?
Thanks
Hi,
PFA the model file as requested.
Sefaira Test Analysis.rvt
Thank you.
Hi
conversion to IFC can be tricky sometimes. While we are dealing with this issue here is a skp model that should work.
Thanks
_sefaira_ready.skp (523.5 KB)
Hi Vladimir,
Thank you! All of the projects we work on are in Revit, so it would be great if it gets solved.
The SketchUp model works well with Sefaira. I’m curious if it was just imported into Sketchup or was it remodeled?
