I succeeded in creating a scalable window. It’s made up of four frames pieces and a glass pane. It works but I wonder how I should get rid of the visible joints. Is there an alternative way of doing this?
By hiding a few edges > window.skp (170.8 KB)
Your window has scalable parts but it’s not a component.
Select all five parts > right click > Make component.
The idea was to see what edges to hide.
You don’t say, but I presume this is a Dynamic Component. It would need to be if you wanted the frame width to stay consistent after scaling.
What an excellent idea. It worked but I forgot to make the glass translucent. When I try to edit component and add attribute/material there is nothing to choose from. How do I add material without exploding the component?
