Hi Chaps,
I’ve been using SketchUp Make 2017 for a while and have just upgraded to Pro 2020 version. My problem is that I can’t seem to find a Round Corner extension that’s compatible with Pro 2020.
I used Fredo Round Corner with my old version, but it’s not compatible with the later versions.
Anyone know of an extension or another way of rounding corners please?
I’m curious what gave you the idea that RoundCorner isn’t compatible with SketchUp 2020. It most certainly is. As Aaron indicates there’s also the newer FredoCorner. You should get both of them because there are some cases where one can fail and the other succeed. This is the author’s advice, by the way. While you are at it, make sure you also install the latest version of LibFredo6. It was updated on May 17.
Glad to help. You might consider installing the SketchUcation Extension Store tool and use it to install extensions you get from Sketchucation. It will download and install them in just a click and help you keep track of when they are updated.
Simply saying something isn’t compatible doesn’t make it so.
Here it is working happily in 2021.
So how about actually telling us something about your issue so we might be able to help you.
The most likely guess would be that you haven’t installed the Library file.
I’ve got now “Trial Period Expired: FredoCorner” message and also for RoundCorner. Why is that if it was free?
Is there any free round corner plugin now?
