Revit importer phase issues
We are trying to standardize a revit to skp workflow using the new importer but are noticing some weird issues that we cant quite figure out.
This is how we are setting the view up.
Unfortunately, I can’t post a snip of what the imported file looks like. (new user)
For some reason it seems like the Phase filter is being ignored and then when we select the existing phase in the customize view window it imports everything, instead of filtering out the demo items.
What we also noticed is that even if you set a scope/section box in a view it doesn’t take it into account.
Are we missing something in our revit settings?
thanks!
This is what the import into skp ends up looking like.
Can you share the file and the number of the build that you are working with?
would a share file be ok? we need to purge some things from it first but ill get it uploaded and send over. thanks,
that works, we can download from the share link.
ok so below is a link to the RVT file. we are all mostly on the up to date importer build. 1.2026.1.4.
https://wetransfer.com/downloads/4dfc521157a91064d6c4b11dac49f94420260121190733/a559d951dbfffe953a28676136f6a07d20260121190845/abc023
thanks again for the help!
Ok, these are the results with the latest Extension Warehouse build 1.2026.1.4:
View: SketchUp - New Construction - Show New
SketchUp Import Results
View: SketchUp - New Construction - Show Previous Phase
Revit
View: SketchUp - New Construction - Show Previous + New
SketchUp Import Results:
Results were consistent between the Revit and SketchUp, not sure if we are choosing a different view. Are you using the latest version 1.2026.1.4?
Really appreciate you working through this for us!
looks like it was a Phase Filter issue on the Revit side. I just tested the same file I sent you and was confused to see it working as well. Turns out our main file has the filtering set differently and was causing the issue all along!
again appreciate you helping with this! lets us know what we need to ask from RVT teams in the future.
Cool, thanks for reporting back. I will send you a private message so we can arrange some time to talk and collect feedback for improvements.
