Revit chair to Sketchup
Hello,
Looking for some help. I have some Revit files of a chair that I need to convert for use in Sketchup. The file doesn’t seem to be working with Trimble connect and my usual way of converting them. I was just hoping someone might be a Revit user and be able to import and export in another 3D format suitable with Sketchup. They might be able to confirm if the files are broken, which would explain why I can’t import with Trimble.
Thank you.
I can’t attach the file as not format the forum allows so let me know and can set up a link to download.
If it is a .rvt file, I enabled that, you can attach your file now.
I can help you. Upload the file.
My guess is that the OP is talking of a .rfa Revit Family file.
I added rfa, rft, and rte.
Yes they are rfa file. I had to head out today but will be back for the evening so will check if it works and if not will upload :+1:
Thanks people
Hi Colin, when you say you’ve added these, is this a function on Trimble or am I missing something else. I don’t work with RFA or RVT files that often, so apologies for silly questions.
Some files here, let me know if that’s worked for you, thanks
He said that he enabled the possibility to attach rfa, rft and rte to this forum.
SketchUp doesn’t support those type of files.
What I am seeing…
Converted to dwg files…
LimeLite-Stacking.zip (1.9 MB)
Amazing thanks @SeanB that’s the ticket
I hope it helps you!
Isn’t SketchUp Studio a future proof solution for you?
Cheers, Orlando
I’m on studio already. You can only import .rvt files, sadly, maybe something for the future but I’m sure there are reason why it can’t be done at present
The manufacturer offers these as DWG files btw
I don’t think people generally design furniture in Revit - usually the Revit family files are packaged geometry made elsewhere, so if a manufacturer is only offering RFA it’s through an error of judgment.
Sometimes and email is all it takes to get a DWG or OBJ file.
Of course, the normal caveats apply and they are often not SketchUp suitable , but at least they aren’t trapped behind entirely proprietary autodesk file formats
Hey @Elmtec-Adam hope you’re pal.
Yes don’t worry had already explored online files, but they were of poor quality, so I was hoping the Revit was were of more use. I also emailed them, and they sent over a much better quality DWG in the end, massive file, but usable. As you say, probably just aren’t thinking about us Sketchup users in their library!
Emh "[…] I have some Revit files of a chair that I need to convert for use in Sketchup. " - thought that was your question all along.
