Reversed text on plot PDF in layout sketchup
Hey all!
I’ve started a project on Layout for my first time. I’m using Windows, and I’m writing in Hebrew. In the program the text is typed correctly (from the right to left), but when I export it to PDF or print it, the text is reversed.
I found out that not all the fonts are compatible for the Hebrew language so I’m using the common ones.
The only solution that I’ve found is typing the sentences backwards. which is very time consuming and complicates the work.
Is there any another solution that can solve this problem?
correct text
Tanks for your time,
Nina
Hi Nina, there are many free sites that allow you to paste in a sentence and give you options of multiple ways to flip your text. Good Luck!
