Gday everybody
i’m new to su
I want to resize a kitchen is there a way to put in new dimensions scale tool works but is finicky to get to a exact dimension
any help appreciated
No Hands
Gday everybody
i’m new to su
No Hands
It’s not immediately obvious that you can use the scale tool for very accurate dimensions. It’s default is scale by a percentage, which can be very hit and miss, but if you put in the dimensions you want including the ‘Unit’ it will scale to exactly what you ask for. You can even mix up metric and imperial in the same action, just so long as you tell it what you want. This works for 1, 2 or 3 axes depending on which handle you pull and what you type.
perfect thanks mate ![]()
