Resize from 3D Warehouse
Hello I have looked at other forum answers to this but it doesn’t appear to be working for me. I want to resize some items from 3D Warehouse to add to my 3D model. But they go massive even when I scale the item and then add the measurements.
If anyone is able to have a look I would be grateful. I can send model by dm.
The sink on the model should be 550 W x 500 Deep x 220 H.
I also tried exploding the sink but it didn’t work either.
Thanks. I am on a Mac.
When using the Scale tool, you can follow the scale factor with a letter suffix for the required unit.
With a pure number, the tool use it as a scale factor.
When followed by a letter the number is used as an exact measurement.
The suffixes that you can use are:
’ for feet
" for inches
mm for millimeters
cm for centimeters
m for meters
If you want more, see this Youtube video:
Thanks. It still didn’t work for me but I drew the measurements out and scaled it that way
Have you modeled your house at something else than full scale? Have you used Millimeters instead of Meters without noticing?
Scaling by actually typing in the required dimension is something I never knew was possible.
Love this forum :+1:
No it is mm but I I drew a line and thne scaled one side to the size and it worked :slight_smile:
