H! I’m trying to render a project by tuesday. I’m using thea. When I use the interactive rendering feature, my model is cut off in the preview and I’m not sure how to fix it. How do I render the entire model, walls, ceiling and all? Also, how do I export it where it’s not super dark and grainy? Please help!!!
If i sent my model to someone who is good at rendering, could you please try it out for me and let me know how it goes? Thank you:)
I don’t use Thea so I cannot give any direct suggestions. Post your model here if you’re willing to share publically, that would help whoever comes across your forum post.
- It seems as if there is a section plane active that causes Thea to only render what’s below the section plane.
- Is it not part of the preset settings that is currently selected, that it only renders below a certain planar height? (I note “Presto MC” as the pre-selected option.
- Render quality will be in the Thea settings. So unfortunately you’ll have to “click around” those settings to make it less grainy and have a quality export. I suspect the export method will be the usual SU File → Export → 2D graphic method, seeing as it’s rendered inside the SU window.
It is likely that using the trial version is limiting features.
It looks like Thea is using a section plane to cut your render.
For the exposure, treat the render like taking a photograph & adjust the exposure/iso speed/F-stop
