OOPR is damaged.pdf (1.4 MB)
When I render in SU Podium it looks like its working and then suddenly stops processing. I get a message that says: OOPR is damaged
What do I need to do to fix this issue.
Have you contacted Podium customer support?
Thanks for the suggestion! I’m waiting for a response.
Do you have any first hand knowledge with this problem? I am inspired by your handle. Mine would be SketchUp Starter
I’m afraid I don’t have any advice for you. I haven’t used Podium for more than a decade.
Which extension do you use for rendering? I’m in a class and Podium is what they are using for instruction.
I use Vray and Kerkythea for rendering. I don’t do a lot of rendering though.
What version of Su podium is installed?
They also have their own dedicated bulletin board, so it might be good to post there:
https://supodiumforum.websitetoolbox.com/categories
I have used Podium, but haven’t gotten that error message. I’m not on Ventura either.
