Rendering problems with SU Podium V2.6 plus
my version of podium ( SU Podium V2.6 plus) crashes everytime I try to render a scene in Sketchup pro 2019. message says I should activate my license, but it is valid and activated.
what can I do to resolve this?
Lot’s of different version of SU_Podium, you might not have the correct one installed. Then there where differences in the way Ruby was implemented in SketchUp 2019, too.
So the version you are using is very important (eg 2019.1 or 2019.3?)
Check this site for more info:
https://suplugins.com/podium/podium-downloads.php
You should deactivate your license and uninstall SU_Podium, first.
https://suplugins.com/v26/install/v26-update-rbz.php
Hi there, I got this kind support from the guys at Cadalog:
“Hello,
Is this crash happening with all SketchUp files, or just one particular project?
Please do this test – create a new SketchUp file. Model a simple cube and then press the render button.
Does Podium successfully model the cube scene?
If that works, it means Podium is working, but there is something in your project that is causing the renders to crash. Usually this would be something with lights or textures – like an LEM material that also has reflection properties, or a PDF file used as a texture (this can cause a crash). If you press the Wrench icon in the Podium toolbar it will analyze the model and generate a report – there is an “Alerts” section that will flag any potential problems with the model.
If the cube test works, please run an analysis on the project that is crashing and past the contents into a reply.
Thank you,
Justin”
Checking my model on crash-sensible items and resolving them, solved the problem also.
I had some materials attributed LEM and reflection characteristics which conflict with each other.
This is the results from my report:
SU Podium model analysis:
SUMMARY
Light Sources:
0 point lights, 0 are turned off.
0 spot lights, 0 are turned off.
3 LEM material
2 Normal LEM
1 Hidden LEM
0 High Intensity LEM
Materials:
3 light-emitting materials(LEM)
8 reflective materials
11 materials with refraction
1 material with bump map
Alerts:
1 DTR problem
0 unexploded images
0 psd materials
0 no extension texture
0 wrong extension
0 materials with Both LEM and reflection (can crash)
0 High Intensity LEM applied to materials (may crash)
DETAILS
Materials Details:
Light-emitting materials(LEM)
“LEM 10” used in 1 face
“Material7” used in 242 faces
“Backlight” used in 2280 faces
Reflective Materials:
“Material” used in 140 faces
“SW 7008 Alabaster” used in 1066 faces
“SW 7029 Agreeable Gray” used in 135 faces
“Bronze Light” used in 210 faces
“Material33” used in 3 faces
“Marble Worktop” used in 43 faces
“[Metal_Corrogated_Shiny]1” used in 4176 faces
“RANGE-BRASS-SOLID” used in 192 faces
Materials with refraction:
“” used in 9 faces
“[Color_000]1” used in 428 faces
“28” used in 68135 faces
“[Color_002]” used in 530 faces
“SW 6187 Rosemary” used in 110 faces
“[Color A01]1” used in 16938 faces
“[Translucent Glass Blue]” used in 3511 faces
Materials with bump map:
“Material1”
Alerts Details:
DTR problems:
“Material” has less than 50% DTR value.
Click here for to read about Analyse Tools.
GENERAL MODEL INFO
Operating System: Windows 10
Sketchup Version: 22.0.354
SU Podium Version: 6.048
There are 2553284 faces, 298 materials, 17 pages, 16 layers, 15 groups and 112 component instances in the model.
Save Results
