Rendering bug in SketchUp Twilight Render
I’m rendering this photo for a while now as you can see. Still, Twilight render struggles with antialiasing. You can clearly see example of that on the drain pype and on one side of a pool.
Am I doing everything correct? Of should I restart render process?
Any help with this would be highly appreciated :smile: .
You might want to contact the Twilight Render folks directly.
But this is not like common problem?
What do you mean? Since you are having a problem with Twilight Render, you should contact them about it. They’re the ones who will be most likely to help you. You could also ask about your problem on their forum.
