Is there a way to prevent the “News 2026 Webinar” notification from reappearing every time SketchUp starts? I’ve seen it once and declined, but inflicting it on every startup is a bit of a diabolical exercise.
Thanks
Thanks
I don’t like these popping things either, especially not when they pip-pop up repeatedly.
Also this cant be switched off currently. (They are working on it … I guess…)
Well, It’s true that it also bothers me - more than others - when/if there’s an artificial idiot lurking in the corner.
You should be able to click the “Start Modeling” CTA in the bottom right to close the window and dismiss the notification for good. If you use the X to close the window, it will show at each launch.
