Indeed that is the method I’m using. My geometry is just a couple cubes.
It just be another plugin. I’ll keep unloading until I find it. Thanks for the reply and video. Good to know it isn’t altogether broken. Just for me. For now.
You might start by temporarily disabling all extensions by temporarily renaming the Plugins folder so they won’t load. If you still have issues with the reloading thing, you would know it’s not likely due to an extension.
Did you install SketchUp correctly by right clicking on the downloaded installer and using Run as administrator?
I think you might be onto something. It’s the SU lottery.
Yes I made sure to install as admin. It’s a work computer and it is possible that even with admin privileges I may be locked out of something—that was the case at my last job.
Regardless, I’ll do the plugin folder rename thing and see what’s crack’n after that.
Thanks again
Must be the file…
Reinstalled as Admin…again…and everything works. Until i try it with the original files that were giving me problems. Works fine with generic tests. Not with this other file
I just did some more testing and it no longer appears to be the file. I attempted to replace with a built-in SU component.
I uninstalled Vray again–no luck. So i uninstalled Enscape preview and I was back in business!
I reinstalled Vray and it still works!!
I’m going to try an older version of Enscape. But i am almost certain that was the culprit.
