Rectangle cannot be done
When I want to make a rectangle I can´t put the size, it doesn´t recognize or the ENTER botton doesn´t work. please help me
Are you clicking in the Measurements window before typing in the dimensions? If so, don’t! There is never any need to click in the Measurements window before entering the dimension.
Are you typing in the dimensions with the correct separator? Either a comma or semicolon. Look at the measurements box before typing and make sure you use the same separator as shown.
Display the subtitles in your language.
This tutorial is not perfect and a bit old but it easily explains how to draw a rectangle with precise measurements. Be sure to look at the separators used by sketchup for the measurements as they may be different from the ones I use in the video.
I’ve been using Sketchup for over a year and have many, many files using rectangles. I don’t think the videos will help because I’ve done those months ago.
Don’t double post! You already started a thread on this topic.
