Quality of 3D images in Layout
You can change the display resolution inside Document Setup > Rendering
The idea would be to keep the display resolution low or medium, but the output resolution high (ie. the PDF export would be higher quality than what you see on your screen) so that you can have a faster drafting experience in LO. You could also upgrade to 2024 as there are performance improvements.
