Push pull suddenly stopped working
Test push pull.skp (131.7 KB)
Unable to use Push/pull tool on a simple test example. Any suggestions
What version of SketchUp? Please complete your forum profile.
Please update your profile. What SketchUp version are you using? It’s important to help you.
The black edge prevents push pull movement.
Also you have to uncheck length snapping. It’s an option you have in Model Info.
There’s something strange going on in that model. The outliner shows an instance of Steve component, yet I can’t find one in the model entities. After deleting that instance, purging unused, and turning off length snapping push pull still snaps to the former setting! I have to run errands now, will look further when I get back.
You’ve got several problems here. First as @rtches pointed out, the upright edge on the right side is not vertical. You can see that in the coordinates of the endpoints.
Second, you have Length Snapping enabled with the snap interval set to 1.00 METERS. Turn off Length Snapping.
Screenshot - 9_16_2024 , 10_31_36 AM
If you want to extrude the rectangle on the ground plane, delete the vertical face and its edges.
@slbaumgartner points out the scale figure of Steve. He’s been shifted down the red axis a ways. If you don’t need the scale figure, delete it, don’t just move it aside.
Thanks for the reminder. Have updated my profile. Am using 2015 Pro
