I’m trying to push the windows in on my building. However, the push/pull tool will only let me push in -1/16’’ or pull 1/16’‘, 1/8’', etc. etc. Essentially, the push/pull tool is only letting me push/pull equidistant or set measurements, and wont let me maneuver the push/pull tool to any distance I want. Any thoughts? (here’s the link to a video showcasing my issue: townhome test 2.skp - SketchUp Pro 2020 (31 days left in TRIAL) 2021-01-27 14-18-25.mp4 - Google Drive )
Most likely you have Length Snapping enabled in Model Info>Units. Disable it and you won’t have that.
FWIW, you could push and then type the desired distance even if it isn’t on the snap interval.
I never manually enabled that, so I wonder why it all of a sudden became enabled? Anyhow, thank you so much!
It’s enabled by default in most templates. Best is to create your own custom template with Length Snapping disabled.
