I know we can repeat push/pull operation by double clicking face.
http://help.sketchup.com/en/article/94889
But when entering push/pull value with VCB, repeating behavior seems to be opposite direction.
I checked all combination, is this spec correct? (see list number 9 to 24)
ummm… I don’t know why the 2nd test works correct direction, is there any problem with my operation?
May be I could specify the behavior.
(1) Pull back side surface. (not VCB, just pull) or Push front side surface. (not VCB, just push)
(2) Pull or Push back side or fornt side surface with VCB entering value.
(3) then all double click behavior becomes opposite.
(1) Push back side surface. (not VCB, sust push) or Pull front side surface. (not VCB, just pull)
(2) Pull or Push back side or front side surface with VCB entering value.
(3) then all double click behavior becomes same.
Try putting - in front of your value when you need the opposite direction.
