Hi, I’m trapdoor (5).stl (20.4 KB)
using solid inspector on sketchup and all seems ok, just short edges seem the only issue, but why on prusa slicer is the top surface always seemingly missing? I have made sure all surfaces face the right way too.
I agree. There’s nothing wrong with the model. It would be a good idea to move it closer to the origin and you might consider removing the coplanar edges to prevent the possibility of making internal faces.
FWIW, I cleaned up the model. Take a look at this. trapdoor.skp (65.9 KB)
I removed unneeded edges and redrew the circles making them smoother by increasing the number of sides. I also got rid of the unnecessary object container. No reason to group a component. Just making the component was enough.
There should have been no need to scale it down. Just export it with the model units set to meters and import into the slicer in millimeters.
