Programatically hide/restore the default tray from the API
Hello,
is it possible to hide/restore the default tray programatically from the sketchup ruby API?
I notice when some of the trays are open the performance of some of the operations in my plugin dramatically fall. I could warn my users about this issue (so they could hide it manually), but It would be great if I could simply hide it programatically before those procedures take place and then restore it.
regards, Carlos
Unfortunately it is not really possible. You can show, but can not hide them…See:
How to make a simple Tray or roullOut in the sketchup? - Developers / Ruby API - SketchUp Community
BTW:
The Sketchup::Model#start_operation have an ability to disable UI updates… (it could help in good part of the cases)
Hi dezmo,
Thanks for the answer!, I will try disabling UI updates, that might solve my issue.
Other solution could be to prevent the user with a warning message to hide the default tray before launching the operations, is there a way to programatically detect if the default tray is hidden or shown?
regards, Carlos
No. :frowning:
(See e.g. here: https://forums.sketchup.com/t/inspector-visibility-determine-whether-a-given-inspector-is-visible/151361 )
Thanks dezmo,
anyway disabling UI updates seems to work pretty well :). so it is even better this way
regards, Carlos
