Hello Forum
has sketched a package that has moving parts,
how do I make it work on stage, where the object moves between the scenes.
Watson9
Hello Forum
Watson9
Generally, when I want to show something such as a cabinet door or drawer moving, I create multiple copies using either Move/Copy or Rotate/Copy. Then I assign a different layer tag to each of the copies so only one needs to be seen at a time. Then by controlling which layers are turned on and which are off, I can show the door or drawer opening.
Here is a desk drawer. I made four copies of it, each in a different position. Each component is assigned a different layer tag, Adrawer1 through Adrawer4.
And below is a succession of views with only one of those layers visible at a time.
or you can use a plugin, e.g. Animator from Fredo6
