Problems putting on roof
You will need to add in your own custom geometry for the covers.
You can either have them external to the roof assembly or if you want them within the roof assembly you will want to use the CUSTOM feature, see Tutorial #20:
In fact, I highly recommend you watch as many tutorial videos as you can so you can be familiar with all of the features of the extension:
Thank you. You are very responsive ; )
Sorry to say, the problem is not solved for me. Downloaded Medeek Truss 3.5.5 and still have problems editing the assembly. I simply will not take all the changes and the construction turns 90 degrees
MedeekTruss355
The outlooker size parameter drop down is blank. Select a valid option and the click submit. If you ever notice any blank drop down boxes make sure they have a valid value.
Ok.
I just reopened file and now it works (without doing anything)
Thank you for noticing me…
